Re: Farmall 130 rocker pins
Posted by Hugh MacKay on October 17, 2006 at 12:07:26 from (209.226.106.104):
In Reply to: Farmall 130 rocker pins posted by Farmall Lift on October 17, 2006 at 11:55:36:
I assume you are talking about the pins that go in the rochshaft arms of the touch control unit. Those little pins about 1/2" x 1-1/4". I say about as they are not exactly that size. I tried but could not find pins the right size from another source that would match.
You may not want to hear this, but the last time I asked at CaseIH they were still available and cost around $8.00 each. Now, that was close to 20 years ago. Needless to say, I found used ones. I got them from a tractor wrecker.
