706 steering/TA
Posted by Tech 7 on October 18, 2006 at 05:55:53 from (69.63.33.207):
Hi...not familiar with these machines so need some info.Ihave no steering at all and the TA doesn"t work in high all the time. Where do I check pressures and what pressures should I be seeing? Thanks, Bob
