Re: Crank Pulley Revisited
Posted by Janicholson on October 19, 2006 at 05:21:22 from (66.173.50.120):
In Reply to: Re: Crank Pulley Revisited posted by gene bender on October 19, 2006 at 02:27:50:
Two possible successes, one no contest:
The first is that the hones I've got in my kit have wide enough stones to bridge the groove.
The second is the use of a bead style hone.
And I would hope that my alternative would provide a solution for the mainstream that have no hone. or who's hone has thin stones/abrasive. Your point is well taken, I should have discussed it clearly. JimN
