Re: Super A mystery
Posted by Super A on October 19, 2006 at 12:16:17 from (208.1.217.193):
In Reply to: Super A mystery posted by Pa. Pete on October 19, 2006 at 09:57:37:
Did you say, was it the left axle or the right? If the left, that bolt holds on the optional seed plate drive sprocket, the one that would turn the fertilizer distributor/planter mechanism if so equipped.
Al
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
