Re: Farmall 706- How does oil get to the Rocker assembly
Posted by Owen Aaland on April 11, 2009 at 15:42:56 from (65.165.246.54):
In Reply to: Farmall 706- How does oil get to the Rocker assembly posted by 4farmallman on April 11, 2009 at 13:06:00:
4farmallman said: (quoted from post at 13:06:00 04/11/09) I have a 1964 gas 706. How does oil get to the rocker assembly under the valve cover? A while back I took the head off my 706 and had it milled because it was leaking around the head gasket. Today i took the valve cover off to retorque the head bolts and there has been no oil at all getting to the rocker assembly or anything under the valve cover. Thanks
Oil is metered through one of the camshaft bearings and then routed to come up around a head bolt up to the rocker arm shaft. If the camshaft bearing in not installed so that both oil holes line up with the holes in the block there will be no oil available to go up into the head.
