Re: Water in gear box
Posted by Patrick martin on October 19, 2006 at 19:54:53 from (64.154.26.250):
In Reply to: Water in gear box posted by John in Aussie on October 19, 2006 at 19:40:37:
I use diesel to flush pretty much everything. It's a light oil and will mix with just about any other oil it also drains and evaporates quick.
Fill your gearbox about halfway and jack up the rear wheels so you have no contact with the ground. Run it in first at idle for just a little while so it can work into the bushings and bearings then drain. It will break down any sludge and gunk you have built up. Don't run your tractor on the ground with 100% diesel in the box because the diesel is far too light of an oil to float between the gears.
I use it as a engine cleaner/flush too. Replace 1-2 quarts with diesel and run till the oil breaks down.
