Re: Crankshaft gear
Posted by JayWalt on October 21, 2006 at 12:26:11 from (24.223.138.48):
In Reply to: Crankshaft gear posted by Andy9455 on October 21, 2006 at 11:32:01:
try wrapping the shaft with a few ice packs as well as heating the pulley. lots of lube too on the shaft. Also, if the pulley is keyed, try without the key to eliminate that being what is causing it to stop.
Was the old one hard to remove?
You can also use a piece of oak and try tapping on it with a hammer, dont get too crazy tho
