Farmall Tractors Discussion Board
Re: a couple H ??
Posted by The Red on January 29, 2000 at 14:42:36 from (12.66.208.75):
In Reply to: a couple H ?? posted by Jeff W. on January 29, 2000 at 14:13:06:
Jeff, 18s should be fine. I have 18s in 2 of my 3 Hs and have had no problems. As my plugs get worn out, I am converting to AC C86s.
On the valve stem/rocker arm clearances, I set mine at .018 when cold and have had no problems.
M castings would indicate a 1943 from Guy Fay's excellent IH Tractor Data Book (Guy do I get a commission for the plug????????????)
Post A Followup
: Re: Re: a couple H ??
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
