Re: Farmall 706- How does oil get to the Rocker assembly
Posted by El Toro on April 11, 2009 at 16:27:42 from (205.188.116.73):
In Reply to: Farmall 706- How does oil get to the Rocker assembly posted by 4farmallman on April 11, 2009 at 13:06:00:
third party image
Were you getting oil to the rockers before pulling the head? If you were, you may have blocked the flow when installing the head or gasket. This explains what Owen was talking about where its highlighted. This is on the lettered tractors. Your tractor may have a similar setup for getting oil to the rockers. Hal
