Re: 656 Quits
Posted by El Toro on October 23, 2006 at 15:35:35 from (152.163.100.65):
In Reply to: 656 Quits posted by Bill 4104 on October 23, 2006 at 14:59:06:
That gas line should have a full flow of gas from that line unless dirt or rust has it obstructed.
If that carburetor has a fuel solenoid at the carburetor it may not be opening or it could be full of dirt. Loosen the gas line and see how much gas is flowing out. I would set a clean container under it to catch the gas. If you have a tiny trickle from that line there's blockage
somewhere between that line and the gas tank.
If there's a good flow to the carburetor you need to check out the carburetor. I may need a good soaking in carburetor cleaner and cleaned thoroughly. An inline filter could be plugged with dirt too. The sediment screen is another culprit. Hal
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
