Re: Farmall H live Hyd control valve question
Posted by Janicholson on October 23, 2006 at 19:13:13 from (66.173.50.158):
In Reply to: Farmall H live Hyd control valve question posted by John in CT on October 23, 2006 at 18:45:35:
I do not think so. There is no reason a tractor could not be equipped with both units (and a seperate resivoir for the Live unit), but to get pressure into the spool valve of the belly pump, and to disable its pressure regulator, and still use the resivoir would be a challenge not worth the time. The belly pump provides less than 800psi(I believe), and the live pump might go to 1200 or 1500psi. (my opinion is to use it as a resivoir, or use both as seperate systems) JimN
