Re: 400 ign problem again,again
Posted by SDE on October 24, 2006 at 03:23:31 from (69.179.11.46):
In Reply to: Re: 400 ign problem again,again posted by Janicholson on October 23, 2006 at 06:13:29:
Hey everyone, I swapped the distributors last night. The spark to the plug was much, much stronger and it started. I will not consider it fixed until it starts five times in the next week or two. I will want to correct the problem in the bad distributor so that I can still use it in my parts tractor. I should swap the rotor to see if that may have been to guilty party. The ohm meter gave the same reading on both of the distributor posts, if I checked it correctly.
Thank you, Steve
