Re: Live Hydraulic conversion for an H???
Posted by Wardner on October 24, 2006 at 10:00:24 from (4.154.240.26):
In Reply to: Re: Live Hydraulic conversion for an H??? posted by CNKS on October 24, 2006 at 08:05:35:
CNKS is right about aftermarket pumps. M&W was one supplier among several.
You should be aware that the IH distributor flange has a SAE #2 layout. That same standard is also used on many hydaulic pumps. You would need to find a pump with the flange on both sides so that the distributor could attach. I believe this is how one of the aftermarket tractor pumps is arranged. The other arrangement is similar to the IH live pump but has the correct bolt spacing for the tractor it fits.
I have all this stuff and I am thinking about running two pumps in front of the magneto just for laughs. It will require relocating the oil filter and crankcase ventilation pipe.
