International 350D utility
Posted by Brenden on October 25, 2006 at 02:54:12 from (205.188.116.133):
I'm trying to find a water pump for this diesel tractor and having trouble.The pump I took off has a keyed shaft that is threaded at the end to hold the pulley on and the only replacement I can find has a pressed on pulley.They wont take my pump as a core because its not what they are sending me.I thought I could rebuild this one but the shaft is junk.Also you have to remove the pulley before the pump because it blocks the bolt holes in the pump so how do you press the pulley on after pump is installed.Any help is appreciated-Thanks Brenden
