Re: Resurrecting Stuck Engines
Posted by SproutW on October 25, 2006 at 05:39:20 from (209.7.177.5):
In Reply to: Re: Resurrecting Stuck Engines posted by F-Dean on October 24, 2006 at 20:49:20:
Each tractor I like to take apart and see everything to know what I have. I always pop the head and oil pan off for a stuck engine. Many have freed an engine and ran it without ever taking the head off. I have a hard time with that myself, and worry of trashing sleeves, pistons and rings with all of that rust and gunk in the cylinder walls. I clean the top part of the cylinders, soak and then clean some more. I repeat that process many times untill she comes free with a little force. The engine I have pictured came loose by hand after I repeated the process. I use everything from diesel, transmission fluid, to seafoam and even heat at times. Then at a minimum I hone the sleeves, clean pistons and replace rings. On wet sleeve engines I remove the sleeves and clean the internal engine block and then replace the rubber sealing rings for the sleeves. The engine pictured had a cracked sleeve due to water damage. You just never know what you will find. Never get in a hurry and take your time.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
