Re: farmall super c starting
Posted by Janicholson on October 25, 2006 at 18:20:25 from (66.173.50.19):
In Reply to: farmall super c starting posted by Ty c on October 25, 2006 at 17:40:30:
If by Hummps, you mean you do not hear a high spinning starter motor sound like you kept the key on too long, but a click and/or nothing, It may be the big switch on the starter. Test as follows: With the battery not hooked up (because you suspect it to be an issue), and the tractor in neutral and brakes locked (or wheels blocked), and with the ignition button in (off) use a good 12v battery (or jump vehicle) and attach the positive cable from the good 12v to the frame of the tractor. Then using the Neg jumper cable, touch the post on the starter switch that is going directly into the starter. Some may have this post under the switch as a small copper post sticking out and will require the removal of the switch to get at it (I do not know if they were common, but I have seen it). This will spark something firece and make the starter engauge if it is good. The engine will turn over. If nothing happens, the starter is open (meaning bad brushes or bad connection) if it spins the switch, wires, or battery is bad. The wires should be #0 size or #00 size and clean at all connections. Good luck, JimN
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
