Farmall Tractors Discussion Board
Re: live hydraulic pump on M and Super M
Posted by Rod A. on January 29, 2000 at 20:39:23 from (206.155.226.213):
In Reply to: live hydraulic pump on M and Super M posted by Rod A. on January 29, 2000 at 19:11:35:
When converting to live hydraulics on an M can you use the existing belly pump reservoir to supply the hydraulic oil? Would it have enough capacity to run both pumps? If the reservoir is used what is the easiest was to tap into the oil supply? What kind of hydraulic oil would you recommend?
Post A Followup
: Re: Re: live hydraulic pump on M and Super M
