Re: Farmall A brake replacement
Posted by Kevin SuperA on October 27, 2006 at 09:21:28 from (216.169.187.141):
In Reply to: Farmall A brake replacement posted by Randy Graf on October 27, 2006 at 09:00:05:
Randy,
You have to remove the bull gear housings to get at the brake bands. Be sure you disconnect the brake band rods from the pedals before you try and pull off the bull gear. The idea is that the brake band should stay with the tractor. However when i went to remove mine the bands were forzen to the pin which stayed with the gear housing.
