Re: F20 electric starter
Posted by F-Dean on October 28, 2006 at 07:39:25 from (67.72.98.91):
In Reply to: F20 electric starter posted by Doug in Illinois on October 27, 2006 at 19:05:25:
For about $70 you can put a new coil, condensor and points in a F-20 Mag that will produce a spart that jumps 3/8 of an inch (enough for any spark plug no matter how badley it is fouled). Also, as noted, you will have to clean and maybe rebuild the Carb. Good Luck!
