Re: 5488 shifting problems
Posted by super red on October 29, 2006 at 07:03:11 from (204.73.103.253):
In Reply to: Re: 5488 shifting problems posted by JJK on October 28, 2006 at 21:25:22:
I checked the tractor out yesterday . the sentry light does not come on the fuses all are good you can hear the trans shift when shifting from 1 to 2 and 3 to 4 and 5 to 6 but 2,4,6 only work . the clutch slips also and the power steering dont work and when not reved up the brakes dont work also but the remotes work . would it be a bad pump? or would it be the clutck packs causing all the problems in the trans or both ? I checked the filters and changed them the oil was clear and no pieces or shavings were found . do I have to split it twice to put the clutch packs in it or split it by the engine ?
