Re: Cub Head Bolts
Posted by daniel h. on October 29, 2006 at 15:06:15 from (66.226.34.159):
In Reply to: Cub Head Bolts posted by Lane R on October 29, 2006 at 06:07:19:
Grade 8 from the bolt house will work for the long bolts, but the short ones are an in between length. Don't use the next available length, as they will protrude into the ports and get carbon on the threads, making later removal much more difficult. A dealer or TM will have the short ones.
