Super M Hydraulic Reservoir
Posted by JOhn Whalen on October 29, 2006 at 19:38:46 from (24.97.227.121):
I have a Super M (data plate says so), serial number 11,000 ish, with the engine mounted hydraulic pump. I do not have the reservoir for this but was told I could install an M reservoir/pump in the belly without the coupling. I have an M reservoir, (5027 is on the casting) but it does not fit! Bolt holes line up but it won't go in the last 1/2 inch. It appears to be hanging up on the clutch round stubs that stick out. Does this make sense? Guess I need to find the below gas tank reservoir somewhere?
Thanks! John
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
