Re: M surging
Posted by Wayne Swenson on October 29, 2006 at 21:12:19 from (71.13.41.243):
In Reply to: M surging posted by Farmall freak on October 29, 2006 at 17:24:56:
These adjustments are done with the engine off.
1. Loosen the 2 screws that are holding the governor tube to the governor housing & gently tap it so it "centers" itself then tighten the screws.
2. Remove the top cover on the governor housing (has the pipe going to the top of the engine) and check governor to carburetor synchronization. With the throttle lever set wide open, the clevis pin should just slip into the governor connecting rod that is in the tube. Adjust the clevis height if needed & lock the nut. You may need small fingers & a right-angle needle nose pliers to make the job easier.
