Re: Hydraulics/Trans fluid question on an H
Posted by Steven@AZ on October 30, 2006 at 07:17:25 from (216.67.213.217):
In Reply to: Hydraulics/Trans fluid question on an H posted by Brian in NY on October 30, 2006 at 06:02:13:
Don't use Hy-Tran in the transmission/rearend. The gears will keep spinning for an obsene amount of time when you push the clutch in, and you will have to grind into gear. Also, there will be more noise from the gears and it will be more likely to leak. Hy-Tran is fine for the belly pump hydraulics, used it in my H for a couple years and was just fine.
I prefer 85w-140 in the rearend/transmission on the A/B/C/H/M and Supers (except SMTA, any TA tractor needs Hy-Tran). It keeps the gears quieter, they stop turning when you push the clutch in, and less prone to leakage through those old seals.
