Re: 300 Utility transmission help needed ASAP
Posted by Janicholson on October 30, 2006 at 17:26:34 from (66.173.50.21):
In Reply to: 300 Utility transmission help needed ASAP posted by DrJK on October 30, 2006 at 12:45:25:
The transmission is in third or fourth. TO get it out take the lever off of the cast shift tower and align the shift rails with a large screw driver. Getting the lever out may require the removel of some small plugs that may be holding in a cross pin. The tip of the shifter lever will need to be built up with weld and ground down to just fit in the rail slots. There are nice photos in the archives as to what they should look like under shifter repair. This is not a big issue. JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
