Re: Farmall Super A Oil Pressure
Posted by Easy1 on October 30, 2006 at 18:58:06 from (75.46.253.9):
In Reply to: Farmall Super A Oil Pressure posted by Farmallrock on October 30, 2006 at 17:11:31:
I rebuilt the pump on my H. The H pump has a cast iron or steel cover. I surface ground the cover flat, cleaned up the rough gear edges, and reassembled the pump. Great oil pressure all the time. I am surprised a cover would be alumimum? The pressure on a gear pump will always move the gears into the cover. The gears are hard, so I guess the cover is designed to wear.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
