Re: To overhaul the engine or not... that is the q
Posted by old on October 31, 2006 at 15:51:41 from (4.245.4.251):
In Reply to: To overhaul the engine or not... that is the quest posted by Mike CA on October 31, 2006 at 15:16:12:
First place I would start is a good tune up and carb rebuild. Then if it still doesn't run right do a compression check. Readings should be around 120PSI plus but they will still run well a little below that. Then just go from there. Theres a lot of little thing that if not right will keep one from running good and still not cost all that much to fix
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
