Re: To overhaul the engine or not... that is the q
Posted by Paul G. in Mn on October 31, 2006 at 16:12:38 from (206.183.177.219):
In Reply to: To overhaul the engine or not... that is the quest posted by Mike CA on October 31, 2006 at 15:16:12:
Mike, does this engine smoke? if it doesnt then id take a look after it has sat for a while at the oil, crack the oil plug and look for any evedence of any water or antifreeze. If both these are ok then id just do a good tune up. Id go through the carb and new plugs wires and points and such. By the sounds of it you are not going to over work this old girl so that is were id start with out going head over heals into a rebuild
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
