Re: Need help with H
Posted by Paul in MN on October 31, 2006 at 17:54:06 from (71.210.159.134):
In Reply to: Need help with H posted by jc newton on October 31, 2006 at 16:40:47:
I had the same experience with my H. Even though that sheet metal plate looks simple from the outside, the inside had baffles that direct the coolant towards the cylinders...they may have rusted off on yours. Do get the correct replacement part, and don"t "make do" with a piece of flat plate. After removing the baffle plate, I stuck the wand from the pressure washer in the block and really cleaned out 60 years of accumulated crud. It makes a difference! The baffle plate was available from FNH and aftermarket "OEM" type suppliers. Hint: guess which was cheaper...by a lot!
Paul in MN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
