Re: H accessibility
Posted by Theman on October 31, 2006 at 18:19:36 from (24.155.161.190):
In Reply to: H accessibility posted by Mike in Texas on October 31, 2006 at 17:47:06:
The H and M are just about scaled from the same drawings. There are exceptions here and there like governors and ignition systems which are common to both. But, the H is nicer to work on because the parts aren't as heavy.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
