Re: How much weight
Posted by Janicholson on October 31, 2006 at 19:01:08 from (66.173.50.14):
In Reply to: How much weight posted by banjo on October 31, 2006 at 18:43:13:
Three things will determine the answer. What is the leverage ratio of the rock shaft at the hydraulic system to the rock shaft at the rear? What is the ratio of the lift arms between mounting and lift point and ball and (second class lever I think). Thereason these are important is that the lift may be powerful enough to lift the front if the above ratios are in favor of force, not distance. And not powerful enough to lift a lazy farm cat if they are in favor of distance. If for every inch of travel of the front rock shaft, the hitch balls go up one inch, I would believe it will lift about 450-500# (a guess). JimN
