Re: What good is an H?
Posted by RustyFarmall on November 01, 2006 at 11:37:33 from (207.32.13.247):
In Reply to: What good is an H? posted by City-Boy McCoy on November 01, 2006 at 09:13:00:
Horsepower is not the deciding factor, over-all performance is what you are looking for, and because the H is heavier, and has taller rear tires, it will outperform the C or super C. You could go to Sears and buy a brand new lawn tractor rated at about the same horsepower as an H Farmall, but guess which tractor will do the most work?
