Re: To overhaul the engine or not... that is the q
Posted by Paul G. in Mn on November 01, 2006 at 14:00:17 from (206.183.177.189):
In Reply to: Re: To overhaul the engine or not... that is the q posted by Mike CA on October 31, 2006 at 22:16:16:
before id mess to much with the chargeing system Id clean and rebuild the carb then new plugs, wires, points and condenser, id also look at the distibitor cap. once you have it purring like a kitten then id work on the chargeing system. I am restoring a 39 M right now and have decided to go 12 volt on it. I put 12 volt bulbs in the lights, going get a 12 volt generator and use the 12 volt battery. I am not doing anything with the starter. It will look the same as a 6 volt set up but like how it easy it starts on 12 volt. Just my 2 cents
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
