Re: SMTA Whine
Posted by Hayfarmer on November 01, 2006 at 18:42:32 from (66.243.249.168):
In Reply to: SMTA Whine posted by Retcol on November 01, 2006 at 15:19:22:
Are you sure it is comming from the hydraulic pump and not the PTO? The PTO tends to whine a bit when disengaged. Solution is to disconnect the seasonal disconnect if still equiped or put a shield on it and run with it in neutral(between engaged and disengaged. If it is hydraulic, do yo have enough oil in system?
