Re: installing a belly pump coupler on my M
Posted by M clunker on November 02, 2006 at 01:51:08 from (12.43.88.52):
In Reply to: installing a belly pump coupler on my M posted by Tim 2 on October 30, 2006 at 18:01:07:
WHen you drop the pump down tape the coupler to the pump shaft so that it stays in place going up and you wont pinch any fingers.then jack the pump up.Dont forget to unhook all piping.
