Re: c113 oil pump
Posted by Janicholson on November 02, 2006 at 08:42:36 from (199.17.6.136):
In Reply to: c113 oil pump posted by werowance on November 02, 2006 at 07:53:49:
They are different and do not interchange. The wear in the plate will cause some loss of oil pressure. The sanding on glass will remove the wear (it takes time, do not grind it, or use 8o grit. 220, then 400 or 600 will be fine. make circles to keep it flat. JimN
