Re: farmall c113 oil pump
Posted by Bill Geer on November 02, 2006 at 09:10:05 from (216.157.203.35):
In Reply to: farmall c113 oil pump posted by werowance on November 02, 2006 at 07:22:35:
Ok I pulled the plate off.
The wear/grove is about as deep as a piece of paper.
I think a half hour and some sand paper you will be good to go.
I check the numbers they match.6098-D
Bill
