Re: How to Fill tires
Posted by Pete76NY on November 02, 2006 at 12:04:59 from (12.33.96.130):
In Reply to: Re: How to Fill tires posted by Nat 2 on November 02, 2006 at 11:38:10:
Look a little closer...if your tube has a 1 pc valve stem that you can only remove the valve stem...it's an air valve, if it is 2 pcs, a part screws out woth bigger threads and a bigger hole for the fitting, it's called a watervalve!
