Re: farmall superC
Posted by Dave_Id on November 02, 2006 at 16:07:07 from (70.112.233.145):
In Reply to: farmall superC posted by scott cline on November 02, 2006 at 15:48:20:
You probably have restricted gas flow from the tank to the separator. Lot's of rust and crud. You may have to pull the tank and clean it. I found that the inline filters can cause more grief than they cure. You can get gaskets at your IH dealer, or you can make a homemade on out of gasket material from your local Napa store. I don't have a clue what could be killing your battery.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
