Re: farmall superC
Posted by gene bender on November 02, 2006 at 16:36:56 from (67.55.226.214):
In Reply to: farmall superC posted by scott cline on November 02, 2006 at 15:48:20:
Take he sediment bowl to your NAPA dealer so you get the correct size they are only 2bucks or so. Have to be rubber but check the housing as someone mite have overtightened and sprung the housing and it will be no good. They will also have the screens.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
