Re: farmall superC
Posted by old on November 02, 2006 at 16:50:03 from (4.245.4.118):
In Reply to: farmall superC posted by scott cline on November 02, 2006 at 15:48:20:
A few questions first. Is it still a 6 volt system or a 12 volt one?? If 6 volt then you probably have a bad V.R. and that drains the battery and that will kill a batterey. If 12 volts you have a short in the alterntor. Another thing is a dead short in one of the wires which will also drain the battey. As far as the carb problem remove the drain plug from the bottom of the carb, turn on the gas and catch the gas. You need to have a good steady flow of gas for 5 minutes or more. If you don't have a good flow take the line loose from the carb and check there for a good steady flow. If you have a good steady flow at the line but not the drain on the carb you have a problem in the carb and it will need to be rebuilt
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
