Farmall Tractors Discussion Board
Re: Traction for a Cub
Posted by Simp on January 30, 2000 at 13:14:58 from (63.11.125.115):
In Reply to: Traction for a Cub posted by Matt on January 30, 2000 at 12:51:41:
You could try adding water to the back tires, which should reduce spinning. This should add close to 500 pounds. If you do this, be sure to put some anti-freeze in there so it won't freeze and cut your tubes. I tractor pull and water in my rear tires comes in handy sometimes. Hope this helps.
Post A Followup
: Re: Re: Traction for a Cub
