Re: 815 with 407 engine question
Posted by K.B.-826 on November 02, 2006 at 19:16:45 from (68.115.91.164):
In Reply to: 815 with 407 engine question posted by Rick in Ont. on November 02, 2006 at 16:42:53:
Those engines don't have an internal balancer. The front crankshaft pulley is also the vibration dampener. Check that out first. If you haven't already, unhook the fan belt and see if the vibration goes away. If you've still got that damaged fan turning you'll get a vibration for sure. Figure out why the fan hit the shroud. Water pump out? Broken engine mounts? Could be somthing related to the flywheel. Also, make sure that there isn't something wrong elsewhere in the combine. Vibrations can travel a long ways.
