Re: sputtering M..
Posted by Brownie 45 on November 03, 2006 at 03:32:18 from (207.177.82.163):
In Reply to: sputtering M.. posted by Farm-all-the-way on November 02, 2006 at 05:56:45:
What happens if you close the choke a small/ large amount when the sputtering starts? If the engine picks up, it is fuel delivery/ lack of fuel problem. Can't remember which person on the board recommended removing the drain plug on the carb bowl & inserting a fitting to bring a clear plastic tube up beside the carb bowl to check the gas level & float action. Should be 1/8 inch pipe fitting. Possible cause of trouble in the ignition dept. could be bad terminal ends/ wires anywhere in the ign. line from the switch to the coil/ points area.
