Re: I Need 300 Row Crop Carb Help!!!!!!!
Posted by Tim Shaw on November 04, 2006 at 05:22:59 from (65.173.120.227):
In Reply to: I Need 300 Row Crop Carb Help!!!!!!! posted by Jose Filgueiras on November 03, 2006 at 20:57:50:
There used to be a felt plug in the bottom of the carb that was held in there by a welsh plug. I just went through the same thing with a 350 carb. I followed Dave Slater"s advise and cut a piece of filter material from a crankcase breather and stuffed it in there and got a new welsh plug from NAPA. You will need to drill a small hole in the plug so the gas will drain if the carb floods. You may still be able to get the choke parts you need from your local CIH dealer.
