Re: Super A Starter
Posted by SuperA-Tx on November 04, 2006 at 10:21:54 from (4.90.5.167):
In Reply to: Re: Super A Starter posted by Gmitchell on November 04, 2006 at 09:08:44:
The ground where it bolts to the frame is clean. I didnt unbolt it from when it started last time so that connection should be good.
It has to be some small problem and thats why I want to keep the pos wire hooked up and ground it with a cable to see if its the starter button or if the starter isnt getting good ground to the frame from the paint.
