Re: My M does not start HELP!!!!!!!!!!
Posted by El Toro on November 04, 2006 at 16:26:58 from (64.12.116.65):
In Reply to: My M does not start HELP!!!!!!!!!! posted by Gebhardt on November 04, 2006 at 16:11:54:
Is this a 6 or 12 volt system? If it's 6 volt you should be using positive ground on the battery. You need to gap your points to .020" if you have a distributor and then clean those points with 320 wet or dry. Then clean them with a cotton swab dipped in alcohol several times. You also need to check for voltage at your coil
with the points open. Use a test lite or a volt meter. If you have voltage here on both small terminals, check at the point for voltage. You need the ignition switch in the on position for this test. Then see if the engine will start. If it doesn't change the condenser. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
