Re: My M does not start HELP!!!!!!!!!!
Posted by El Toro on November 05, 2006 at 03:54:13 from (152.163.100.65):
In Reply to: Re: My M does not start HELP!!!!!!!!!! posted by Hey Nat on November 04, 2006 at 17:15:21:
You need to find out why there's no voltage at the coil. Check the the ignition switch for voltage output, if there's no output voltage check for voltage coming in to the switch. If there's voltage present at the input side of the switch,your switch needs replacing. No voltage to the switch you need to keep tracing that feed wire back to the voltage source. Some are fed voltage from the starter solenoid and that wire could be broken.
You can run a separate hot wire fron the battery to the coil to see if the engine will start. I wouldn't be replacing parts until you find the voltage problem. If you're using negative ground
the wire from the _ negative terminal on the coil should go to the distributor. Clean those points too. Hal
