Re: H Carb Adjustment???
Posted by old on November 05, 2006 at 07:48:59 from (4.245.3.57):
In Reply to: Re: H Carb Adjustment??? posted by Mike CA on November 04, 2006 at 23:05:41:
Mike the carbs on tractors are so simple that most of the time the problem isn't really the carb but dirt in them and it getting missed when they are cleaned up. Carbs on an H will have 3 adjustments. 1 is an idle screw, one is a main jet and the other is a idle stop. A lot of times due to being old the main jet goes bad and needs to be replaced because the hole has gotten bigger then it should from people thigheniing down the adjustmnet to hard etc.
