Re: Tractor stands?
Posted by john d on November 04, 2006 at 11:03:36 from (69.130.179.45):
In Reply to: Tractor stands? posted by Mike CA on November 05, 2006 at 00:00:47:
An easy way to support the rear section when splitting a tractor is to use a pallet jack rolled under from the back side. Crib up under the belly of the tractor with 4x4 timbers and once it's detatched just roll it back out of the way. This will let you adust it up and down when re-aligning the two halves.
The front half must be not only supported well, but kept from tipping sideways. A simple frame such as shown in a post below will do this safely on a tractor with a wide front. If it's a row-crop, or narrow front tractor, the stands attached to the sides of the frame rails need to have a "foot" on them to the left and right that is long enough to prevent the entire front half from falling sideways when you start yanking on wrenches or pushing things into place.
DO NOT use cinder blocks, cement blocks or a simple bottle jack under the center of it!
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
